Surveying vs Engineering vs Mapping
Can any of you provide some insight on the distinction between surveying services, engineering services, and mapping services? My firm is a registered engineering firm in Louisiana. We have two PEs on staff (myself and my business partner). We are a very small environmental consulting firm that also provides GIS and Mapping services. I am a certified GIS Professional (GISP) as well as my GIS Manager. According to the Louisiana Professional Engineering and Land Surveying Board (LAPELS), there is a close relationship between land surveying and some areas of engineering. Based on our interpretation of the rules, mapping functions which require the establishment of relationships to property ownership boundaries are unique to land surveying and must be performed by a PLS. Pretty much every other type of mapping function can be performed by a PE or PLS. We do not perform property boundary surveys but we do provide many types of other mapping services. I think we are fine, but after LAPELS recently sent letters to every pipeline company in the state warning them to ensure their contractors were properly licensed and following the rules, I just wanted to double check.
I've attached the portion of the LA rules that discusses surveying and mapping.
RE: Surveying vs Engineering vs Mapping
That said, I've also adopted a similar understanding to yours; that property lines and other "for record" surveying must be done by a PLS. But making a contour map for a engineering hydrology study or something similar is not surveying. Otherwise why are engineers taught basic surveying in college? I bet if someone really wanted they could still get you in trouble for it, though. Probably best to check with your local engineering board to see what their take on it is.
Maine Professional and Structural Engineer. www.fepc.us
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
In the example cited by LAPELS, I would think alignment drawings could be prepared by a PE or PLS. Typically, alignment drawings aren't boundary surveys, so a PE stamp should be fine.
I'd rather not open up Pandora's box by contacting LAPELS either.
TTFN
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
