Find neighbouring/nearest nodes APDL?
I'm wondering if there is a way to find neighbouring or nearest nodes in APDL? I know I can use the NODE(x,y,z) command and that will find the nearest node to the point x,y,z. But I'm wondering if there is a different command that will tell me the numbers of the neighbouring nodes given a node number?
I think it might be possible to write a routine that can do this, but it could be time consuming to write and to run so I was wondering if there is a command or subroutine already out there that would do the job?
George
RE: Find neighbouring/nearest nodes APDL?
What do you mean by "neighbouring or nearest nodes"? Do you mean attached to the same element as a particular node? Or within a finite range of a particular node?
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Hi Drej,
I mean within a finite range of a node. From the way I am creating my mesh I know the number of the nodes that are part of the same element as a particular node. I'd like to automate the process of finding the nodes that are nearby but not part of the same element.
George
This code will get you started.
It selects a finite box of nodes based on a centre node ("nodenum") and a range which is box shaped ("range"), where the box edge lengths are twice the "range" variable. It only works in 2D also (X and Y plane) but easy enough to extend.
CODE -->
! Identify a node number and a finite range
nodenum = 1795
range = 2.6E-02
alls
nsel,s,node,,nodenum
xloc = NX(nodenum)
yloc = NY(nodenum)
nsel,s,loc,x,xloc-range,xloc+range
nsel,r,loc,y,yloc-range,yloc+range
nplot
Hi Drej,
Thanks for the script, that should find all the nodes within a bounding box. I've found another command NNEAR(x), that will find the nearest node to node x, it only returns one node and I'm not sure how it decides which one when there are several nodes all the same distance apart from the target node.
George
Create spherical locaL coordinate system, located at the node around which you desire to find other nodes. select new nodes based on the radius.
Commands
Local....
Nsel, s, loc,...
