Solid state transformations - reduction in thickness
Good day for all...
I have a very experienced colleague in the refinery I work on that is affirming that Solid State Transformations also cause thickness reduction.
Is this affirmation correct?
The situation is that we have a failure in one steam generator tube (convection section) and the same has an important internal thickness reduction of 0.23" in three years (T actual = 0.07/ T nom = 0.3) in the part of tube looking at the fire side. It also have a small bulging with a crack through. He is attributing the failure to Short Term Overheating and Steam Blanketing which sounds reasonable but I asked about the thickness reduction and his answer was that the excess of heat could have caused a solid state transformation and subsequently a thickness reduction. That last statement made a lot of noise in my head so I bring this to you to get your input and opinions.
I attached a picture of part of his report.
Kind regards,
RE: Solid state transformations - reduction in thickness
Local deformation from stress rupture would cause the observed local thinning.
What is your colleague experienced at? I don't suspect it is metallurgical failure analysis.
"A little learning is a dangerous thing.” - Alexander Pope, 1711
"Very little learning is a very dangerous thing.” - Brimstoner, 2011
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
