Calculate capacity of pier with Welded Wire Reinforcement
How does one calculate the vertical and horizontal load capacity of a pier reinforced with welded wire reinforcing? Is it essentially the same as with rebar reinforcing...just find the area of steel in the section? Didn't know if there was anything different. Thanks.
RE: Calculate capacity of pier with Welded Wire Reinforcement
Thaidavid
