pressure pulsation at rated point
Hi all
I started LMV322 pump and contentiously open the discharge valve from 25 % to 70 %, all things are OK. Note that in this condition, flow is in rated point. Once i want to open the discharge valve a little more,discharge pressure Gage and Amper monitoring fluctuated and by returning to its previous state (70%), the problem is not solved.
process Conditions:
suction pressure=5.5 bar g
vapor pressure= 4.5 bar a
Q=2300 kg/h equal to design point
Liquid: Buten
the question is "What can result in pressure pulsation!?" and how can solve it?!.
Has anyone else experienced similar problem as I have described?
process Conditions:
Liquid: Buten
RE: pressure pulsation at rated point
Bellows Manufacturing and Research, Inc.
https://bellowsmfg.com
