Size tolerance
Size tolerance
Size tolerance: part measure from a flat surface (I am indicating the height of a part). Is this a correct statement?
How about thickness of a part?
RE: Size tolerance
John-Paul Belanger
Geometric Learning Systems
RE: Size tolerance
The terms size, height, thickness and tolerance have different meanings. A measurement is not a tolerance. And depending on how the part is positioned on the flat surface, the measurement could be a height, length or width.
RE: Size tolerance
