Maximum Reinforcing Spacing
RE: Maximum Reinforcing Spacing
Have you checked the concrete strength? It looks like you used 40,000 psi concrete, which is probably not correct input. If you change it to 4000 psi, the spacing will be fixed it right away.
This is why I like Tedds. I can look thru the calcs and see where it starts looking wrong....
That's 2/3 of the reinforcing yield strength (2/3 x 60,000).
