a question about vusdfld subroutine.
Hello everybody,
I have a question about VUSDFLD subroutine. I want to get Stress and Strain in any material point and we know that vgetvrm utility routine should be used. my question is here: for example in vgetvrm('LE',rData,...), rData (1) in any increment is standing for which material point??
RE: a question about vusdfld subroutine.
Number of material point is under kIntPt variable passed with VUSDFLD subroutine.
Bartosz
KIntPt is the number of Integratiopn points of element, i want to know that rData(1) is for which element???
I have another question,
How i can check that rData(1) for my whole model is true??
i mean how can i present (for example) (rData(1)+rData(2)) in the visualization window??
First you have to understand how Abaqus call VUSDFLD subroutine.
It can be more than once and depends on number of elements and element types in your model.
Number of the subroutine calls depends on element type and equals number of section points:
1) membrane with reduced integration (M3D4R)
- has one material point
- one section point per material point
- Abaqus calls VUSDFLD only once (1x1) per increment
2) shell with reduced integration (S4R)
- 5 section points per material point (depends on shell section parameters)
- Abaqus calls VUSDFLD five times (1x5)
3) shell with fully integration (S4)
- has four material point
- Abaqus calls VUSDFLD twenty times (4x5)
In VUSDLFD you have variables to check which material point (kIntPt) and which section point (kSecPt) is used in current call.
Now we need to find element number. Id of elements is in jElem variable.
So if read rData(1) and jElem=1000, kIntPt=3 and kSectPt=2 you got output for 2nd section point of 3rd material point of element 1000.
This is true for one element model. When you have more than one element things are a little bit more complicated.
First you have to understand that Abaqus/Explicit does not call the subroutine for each element separately.
But instead he takes group of elements and pass into VUSDFLD. nblock variable has information how many elements is in the group.
So if you have two S4 elements you do not call the subroutine 40 times but still 20 (total number of section points for one element in the group).
jElem is array with id of all elements, so it can be like this [10, 33, 55] if nblock=3.
In one call you read 1st section point (kSecPt=1) of 1st material point (kIntPt=1) of three elements (jElem=[10, 33, 55]).
In next call you can read 5th section point (kSecPt=5) of 3rd material point (kIntPt=3) of these elements (jElem=[10, 33, 55]).
As you can see in one call you always read the same section point and material point but for many elements.
GETVRM gives you one rData array with all outputs. It's clear what section/material point because of kSectPt and kIntPt variables.
To know which element we need to know relations between rData and jElem array:
rData=[S11_jElem[1], S11_jElem[2], S11_jElem[3], ..., S11_jElem[nblock], S22_jElem[1], S22_jElem[2], S22_jElem[3], ... , S22_jElem[nblock], ...]
where:
jElem[x] - element id on x position on jElem array
Please read this:
http://www.eng-tips.com/viewthread.cfm?qid=303320
Values of field variable you store with field(nblock,nfieldv) variable can be save as field output (FV).
You can also save state dependent variables with stateNew(nblock,nstatev) and use SDV field output.
Bartosz
It was great in depth help for me to know what is going on in VUSDFLD,
I am going to study more about this subroutine and I hope that my next questions be more challenging ones.
thank you again
sincerely yours, Ali
I have faced with another question,
If I want to use field(nblock,nfield) or stateNew(nblock,nstatev) to show for example "S11+S22"
I write the code and it is ok when i define a field variable in Material property but I don't need a definition of field variable there and as I don't define a field variable run is aborting and in *.dat file there is two warning message:
***WARNING: OUTPUT VARIABLE FV HAS NO COMPONENTS IN THIS ANALYSIS FOR ELEMENT TYPE C3D8R
***WARNING: THE *USER DEFINED FIELD OPTION HAS BEEN USED, BUT THERE ARE NO USER-DEFINED FIELDS ACTIVE IN THE MODEL. USER-DEFINED FIELDS MAY BE ACTIVATED BY THE *FIELD OR *INITIAL CONDITIONS,TYPE=FIELD OPTIONS OR BY DEFINING MATERIALS WITH FIELD VARIABLE DEPENDENCIES
I have no idea about "USER-DEFINED FIELDS MAY BE ACTIVATED BY THE *FIELD OR *INITIAL CONDITIONS,TYPE=FIELD OPTIONS"
can anybody help me please?
I appreciate your attention
The warning message has nothing to element type.
It is related to material definition in your model.
You have material with *USER DEFINED FIELD, it means you want to use field variable controlled with USDFLD/VUSDFLD subroutine.
There is nothing dependent on field variable in your model like density/elasticity/plasticity/... .
Your material definition is probably:
CODE
CODE
You have to options to add field variable to your model:
1. use *FIELD keyword (it is not work with USDFLD/VUSDFLD but with UFIELD/VUFIELD)
2. use DEPENDENCIES option in material definition (as showed in example above).
In other words you told Abaqus "use filed variable" and Abaqus say "great, but where?".
Bartosz
VIM filetype plugin for Abaqus
https://github.com/gradzikb/vim-abaqus
