Using multiple datum curves for a sweep
I've got a part with several intersecting datum curves that represent the cutter path for milling operation. I want to create a sweep along these curves, but as they don't form a complete closed loop, I can't create the sweep as a single feature.
Any ideas how I can do this so that the single sweep updates if the base curve is modified?
RE: Using multiple datum curves for a sweep
Michael
