Controlling threaded holes by expressions... NX9
Is this possible?
I've built a number of library parts and some of them have tapped holes that change sizes based on other inputs.
Ex: 3/8-16 becomes a 1/4-20 at the same location.
I've never seen a way to switch these up other than the dialogue. So, up until now I've just shown the tap drill using the basic hole feature which is controllable by an expression.
TIA for any help
Dave
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: Controlling threaded holes by expressions... NX9
Attached is a sample part. Open it and go to the expressions dialog and simply edit the expression named 'Thread_Size' from "3/8-16" to "1/4-20" and hit OK and the threaded-hole will update. As long as you enter a valid thread size this is how it's done.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
