Lateral Bracing
Lateral Bracing
Lateral Bracing
Hi, I have an issue with this option.
I created a steel beam with a length of 3m, with one brace point at 1m.
When I check the unbraced lengh at location before an after of the brace point, the results are the same. 2m at both locations.
The unbraced lenght before the point should be 1m, and after the point should be 2m.
I 'm doing something wrong ?
Thanks!
