help with cfrp
help with cfrp
Hi, i'm new in this forum & i have question about frp and mgf
1- what the diffrence between them?
RE: help with cfrp
A thin film is a layer of material ranging from fractions of a nanometer (monolayer) to several micrometers in thickness. Electronic semiconductor devices and optical coatings are the main applications benefiting from thin-film construction.
http://en.wikipedia.org/wiki/Thin_film
Fibre-reinforced plastic (FRP) (also fibre-reinforced polymer) is a composite material made of a polymer matrix reinforced with fibers. The fibres are usually glass, carbon, aramid, or basalt. Rarely, other fibres such as paper or wood or asbestos have been used. The polymer is usually an epoxy, vinylester or polyester thermosetting plastic, and phenol formaldehyde resins are still in use.
FRP involves two distinct processes, the first is the process whereby the fibrous material is manufactured and formed, the second is the process whereby fibrous materials are bonded with the matrix during moulding. FRPs are commonly used in the aerospace, automotive, marine, construction industries and ballistic armor.
http://en.wikipedia.org/wiki/Fibre-reinforced_plas...
RE: help with cfrp
RE: help with cfrp
Carbon fiber–reinforced polymer, carbon fiber–reinforced plastic or carbon fiber–reinforced thermoplastic (CFRP, CRP, CFRTP or often simply carbon fiber, or even carbon), is an extremely strong and light fiber-reinforced polymer which contains carbon fibers.
The primary element of CFRP is a carbon filament; this is produced from a precursor polymer such as polyacrylonitrile (PAN), rayon, or petroleum pitch. For synthetic polymers such as PAN or rayon, the precursor is first spun into filament yarns, using chemical and mechanical processes to initially align the polymer atoms in a way to enhance the final physical properties of the completed carbon fiber.
http://en.wikipedia.org/wiki/Carbon-fiber-reinforc...
RE: help with cfrp
RE: help with cfrp
RE: help with cfrp
The most important characteristic of a composite material is its layered configuration. Each layer may be made of a different orthotropic material and may have its principal directions oriented differently. For laminated composites, the fiber directions determine layer orientation.
Sandwich structures have two thin faceplates and a thick, but relatively weak, core. The core is assumed to carry all of the transverse shear; the faceplates carry none. Conversely, the faceplates are assumed to carry all (or almost all) of the bending load.
