Arrow out extension NX10
Hi all,
I am currently using NX 10 and stumbled across this problem in Drafting (refer attachment). I try to find settings inside Customer Default and all I can find is "Dimension Arrow Out Length Factor". But the settings didn't do any changes on the arrow out extension. I found this thread http://www.eng-tips.com/viewthread.cfm?qid=354043 but still I don't have any clue.
How can I change the arrow out extension?
Safar
Safar
RE: Arrow out extension NX10
I've been looking for a solution for this too and thus far there is no elegant way of doing this.
2x NX9.0.3.4 and NX10.0.24 Mach Design
on win7 64bit
NX Beta Tester
1x Solid Edge ST2
Menu -> Tools -> Drafting Standard...
...and you select the desired standard and then any new dimensions added will now comply with whatever you had set in Customer Defaults.
Note that you can also go to...
Preferences -> Drafting -> General/Setup -> Workflow
...and in the section of the dialog titled 'Drawing', set the 'Settings Origination' to 'Drawing Standard' and that way, when you open future Drawings any new dimensions added will comply with whatever standard you last set in Customer Defaults. Otherwise it will use that standard that was in effect when the Drawing Templates were created and last saved.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the solution. It worked!
SAFAR
