Abaqus- Temp-disp coupling analysis- sequential steps used.
Hi everyone,
I have to do thermal-mechanical coupling analysis of a cantilever beam where several steps are present.
STEPS:
1. HEATING ( from 25 deg C to 130 deg C)
2. LOADING (1.3 MPa)
3. COOLING (before cooling i am holding the free edge of the cantilever and cooling down the temperature to 25degC)
4. UNLOADING (before removing load i am unholding one edge and same magnitude load is applied in opposite direction)
5. HEATING (holding both the edge and i am heating again to 130degC)
I have done the analysis till the second step. But in third step i am encountering a problem. In COOLING step i suppose to change the reference temperature to 130degC from 25degC. But in HEATING step reference temperature should be 25degC.
I am unable to find out a way to change the material values in different steps. Can anyone help me?
I have attached .cae file here.
Note: I am using temp dependent young's modulus and expansion coefficient with ref.temp=130degC.
Problem : stress value is shooting up to 97 MPa in cooling step. But analytically the value should be around 8.6 MPa.
RE: Abaqus- Temp-disp coupling analysis- sequential steps used.
Hi everyone,
STEPS:
Why don't you add additional material data at other temperatures? Just add lines to create a table of these data. That's possible for nearly all kinds of material data.
Example at linear elasticity:
210000, 0.3, 20
200000, 0.29, 100
180000, 0.27, 200
