Somewhat basic questions about forces applied to levers
I am admittedly a tadpole in this world, so if you cannot bring yourself to respond positively then I understand.
I am developing an interest in remote photography, where cameras are either mounted high on stands or suspended from kite rigs and controlled remotely. Many different designs exist for the actual framework which holds the camera, and I am curious about the most efficient way to pivot or rotate a given load as it relates to the position of the actuator/servo and the pivot point. I would suppose there are some rudamentary instructional axioms which govern how to efficiently apply force to levers and pivot points to reduce the strain on the servo as well as generate the most amount of transferred force on the load.
This is just a random picture off google search as an example:
PICTURE OF KAP RIG
IF you look at that image, the tilt motion looks to be direct drive from the servo. I would think that there is a better way to apply that rotational power.
Additionally, if I have published this thread in the wrong section of the forum, I apologize in advance.
Nicholas
PICTURE OF KAP RIG
Nicholas
RE: Somewhat basic questions about forces applied to levers
Note that this type of gimbal will not do image stabilization, or will not do it well, so long lens imagery will tend to be blurry. Even still, if the UAV is small, it will have its own rotational disturbances, so some sort of electronic image stabilization should be looked into if video output is desired.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Mike Halloran
Pembroke Pines, FL, USA
