Damge progression in material
Dear abaqus users,
In terms of damage progression in abaqus/standard, do we need a predefined path? Thanks.
Vicky
Vicky
RE: Damge progression in material
i guess you want to model crack propogation. If you deal with isotropic Material model and under unidirectional testing you can do that and this the easiest failure creteria. How everything, if you are dealing with composites original nonhemogenous Material your intrest is to find how and in which direction the crack propegates. I how this help.
If you are looking at just damage then as long as your material models contain failure and damage evolution criteria you dont need to predefine the path.
Please ready about element revol Priesters which can be Found.the in dynamic analysis in abaqus.
Any idea about solution in static analysis in abaqus?
