Pump design for maximum flow
Guys,
I have 2 duty pumps for a storm water pumping station. Is it absolutely necessary that we design these 2 pumps for 100% of the flow capacity? What are the factors that would determine this decision.
RE: Pump design for maximum flow
How quickly can a pump be replaced? How soon will it be noticed that a pump is not operating. If this is a short time with respect to the flow coming in, then each pump could be less than 100% of the peak flow. If not, they should be 100%.
If you go less than 100%, I would not go less than 66% on each pump, 75% would be preferred. That way, if there is ever a time the real peak flow is more than the calculated flow, then you have built in safety factor.
If I understand you correctly you're asking do we need to have 2 x 100%?
There is no absolute in this - it depends on what your operational issues are and the consequences of one unit not working. Only you and the client know that.
The factors would include cost, space, control equipment to turn one off / auto switchover from duty to standby, actual capacity of a single pump, consequence of failure, time to repair / replace, how often they are needed, run time per year, probability of failure / reliability, maintenance undertaken, testing of operation, confidence about the maximum inlet flow etc.
I have seen a few systems where influx of water is such that to cope with the rare peak demand, you have 2 x 100%, but if one is overwhelmed then you have 2 x 100%, but haven't oversized the pumps and power supply.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Mike Halloran
Pembroke Pines, FL, USA
