Transformer Neutral Grounding Reactor
Need help understanding the ratings of an existing neutral grounding reactor -
It is installed on the neutral of a D-YG transformer, 13.2KV L-L.
The documentation states it is rated 5.99 ohm, 15.9 mH, 100A, 7.6 KV, 60 Hz.
What does the 100A rating signify? 5.99 ohms at 7.6 KV would suggest much higher currents. Is this a 10s rating?
RE: Transformer Neutral Grounding Reactor
Hope that helps.
