NX Viewer Printing
NX Viewer Printing
Looking for some help setting up printing with NX10 Viewer. The viewer does not have a plot command, only print. I am struggling to find a way to print 1:1 scale, properly centered on the sheet. Once I find a setup that works (tricking the printer with an oversized page size), I try a different printer and I have to start over. The viewer needs to work with a variety of printers and plotters depending on where in the building various users are working. Any suggestions would be greatly appreciated!
RE: NX Viewer Printing
Are you trying to print models or drawings ?
John FILION
Senior Design Engineer
SWAROVSKI LIGHTING
The plotting function in full blown NX works differently in that it creates a CGM first then sends that to the printer/plotter.
I think you either have to consider a base drafting or design bundle to get access to plot functionality or speak with your Siemens rep about finding a solution that will work for you.
I don't think that's an unreasonable request to be able to print plots at 1:1 from NX Viewer.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
I had a look, the NX Viewer doesn't have neither the pdf nor the Plot...
If your salesrep has promised you this option in the Viewer, -it's time to start negotiating...
Tomas
John FILION
SWAROVSKI LIGHTING
