API 650 tank bottom plate extension
Hi, Im performing a rehabilitation of a 35' diameter tank. I need recommendations for seal the tank bottom plate extension to the concrete base to avoid corrosion and water accumulation. Any help?
RE: API 650 tank bottom plate extension
Grout? Caulking? Use a drip ring?
