Changing general solution controls not saving
I have a model that is failing after 5 attempts on certain interval. I am interested in increasing the number of attempts abaqus makes to see if it can converge at a later value. However when I change the IA setting in general solution controls the program is not saving this value and using it in the solver, so the analysis ones again stops at attempt 5 instead of trying for more attempts.
Does anyone know why this value might not be saving in the solver?
Thank you,
-Clay
Thank you,
-Clay
RE: Changing general solution controls not saving
- check also the .msg at the beginning if your modifications are taken
