Catia / Enovia V5 - DSLS problem/s after windows update
If you are running the Dassault Systèmes license service (DSLS), up to R2014X, for Catia or Enovia CAD program/s, avoid or uninstall Windows Update KB 3061518.
RE: Catia / Enovia V5 - DSLS problem/s after windows update
DSLS R2015X is compatible with windows update
check DS Knowledge Base Article (QA00000039250) for more info
Eric N.
Agreed, when the MS patch KB3061518 is applied to a Catia client machine, it loses connectivity to the DSLS license server. Once we updated the DSLS license server to version V6R2015x.FP.CFA.1517, this issue went away.
There is also a workaround without updating the license server. You need to add a system variable called "DSY_DISABLE_WININET" with value "TRUE".
