Stainless steel Issue
Experts,
As we know, there are several grades of stainless steel (304/04L; 16/316L, Duplex 2205, Superduplex 2207...).
How can I choose the right stainless steel for a specific application?
My problem is: I have a water flow (water & gas) (production unit piping) flow with CO2 content 5% in the gas, Temperature 35°C and total pressure 35 barg. I assessed the corrosion rate and I found that it is very high for carbon steel so I decided to upgrade to austenitic stainless steel (304 or 316).
Do I choose 304 or 316? and why?
How can I convince my boss of the choice made?
RE: Stainless steel Issue
Use your work to show that CS is not suitable, and then hire a consultant how specializes in this field.
There are many books on the subject. A good general one is "Stainless Steel for Design Engineers" by McGuire from ASM.
There are also specialty books focused on the petrochem industry.
In general, the alloys become more corrosion resistant (resistant to Cl pitting) as the Cr, Mo, and N levels increase.
304L is the basis.
316L is not economically viable, it is being replaced with 20-21% Cr lean duplex grades (2101, 2002)
2205 is a duplex that holds the mid-ground between lower alloys and expensive ones.
Above here are the super-xxxxx grades, they come as austenitic (AL-6XN, 254SMO) which are very expensive, ferritic (Sea-Cure and AL29-4C) which are only available as thin sheet or thin wall tube, and duplex (255, 2507) which are difficult to work with.
Chiheb Gouta
M.Eng Mechanical
You need to understand corrosion theory and the chemistry behind it, and then you need to know the environment, and then consider the pros and cons of each alloy group, then consider alloys within the selected group.
One of the serious issues is that minor contaminates in the system often control the corrosion.
You need some classes, and you need to hire an expert to lead you through this.
b)What about max normal external surface temp? Is this pipe in a coastal location or offshore?
c)What pipe dia are we looking at?
d)This is production gas, so youve got dissolved chlorides ? Any other contaminants?. List these even if these are in trace concentrations
georgeverghese,
a) yes max temperature is 35degC.
b)the pipe is in a coastal location.
c)18".
d)we are dealing with gas free of any contaminant.
Chiheb Gouta
M.Eng Mechanical
d)It may be clean from a process point of view, but 10ppm Cl makes a difference in corrosion, and if this water came out of the ground it is loaded with minerals and salts.
From a corrosion perspective the questions are different from the process issues sometimes.
Based on your initial question, I will choose 316 instead of 304.
However, I do agree with the rest to get more information first before you make the decision. There could be other alternative materials better than 316 after you access the whole situation.
Jeffrey
External chloride SCC sets in at approx 55-60degC on austenitic SS.
BTW, is this pipe insulated?
Chiheb Gouta
M.Eng Mechanical
I have been testing samples for years and find that while there once was a gap, it has almost vanished.
316 is becoming a grade with a high price and no reason to exist, the lean duplex alloys are pushing it out of the mainstream.
If a SS is the right answer for this application go with a lean duplex (2101, 2202, etc).
They are strong so you can use thinner walls (less metal to buy, less to ship, and faster welding when you install), they also have some functional CSCC resistance (I have seen external SCC on 3xx pipe that was indoors and never got above 40C).
Better not to depend on materials selection but adopt maintenance rules.
If there is time it is better to make trials in real operating ( and shutdown ) conditions. Variations are as important as design conditions. There usually is not enough time in an actual project. Corrosion exercises have to begin years before the project.
