Calculating Bolted Joint Stiffness
we are modelling some bolted joints using CBUSH elements in FEM. can anybody help what is the difference in using huth method and using AG/L to calculate shear stiffness. Thanks in Advance.
RE: Calculating Bolted Joint Stiffness
Best approach - fab a two row joint specimen, test it, measure displacement. Then correlate your FEM approach to the test.
