FOOTING DEPTH
FOOTING DEPTH
what is the "minimum" depth of a footing from the ground line if the building is a three-storey with no roof load. i was thinking of 0.5 M depth due to an existing drainage system underground. thanks!
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: FOOTING DEPTH
So my answer is as deep as it needs to be.
Unless you can more accurately define your scenario you likely won't get any reasonable responses.
RE: FOOTING DEPTH
RE: FOOTING DEPTH
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
RE: FOOTING DEPTH
RE: FOOTING DEPTH
RE: FOOTING DEPTH
.5 meters or 18" is very common here.
Mike McCann, PE, SE (WA)
RE: FOOTING DEPTH
RE: FOOTING DEPTH
RE: FOOTING DEPTH
