Fatigue of MS Bolt in Shear
What is the fatigue detail category for a mild steel (4.6) bolt in a snug tight shear connection? Can you provide a reference?
e.g. AS4100 gives Detail cat 100 for "BOLTS IN SHEAR (8.8/TB BOLTING CATEGORY ONLY)"
RE: Fatigue of MS Bolt in Shear
Constant Cf 22 x 10^8
Threshold Fth ksi (MPa) 7 (48)
Potential Crack Initiation Point "In net section originating at side of hole"
With the exception of Table J3.2 that shows the nominal strength of various fasteners, an ASTM A307 mild steel bolt is not mentioned within the AISC Specification.
