reducer nozzle
reducer nozzle
Instead of a straight pipe as a nozzle, could a concentric reducer be used as a nozzle? If yes, when performing nozzle thickness requirements of UG-45, which diameter would be used? HELP IS HIGHLY APPRECIATED
RE: reducer nozzle
2) Ask yourself, "If I base UG-45 thickness on the small diameter, and the large diameter doesn't make, what do I do?" I'd think the answer would be obvious :)
Mike
RE: reducer nozzle
Luckily I am exempt from reinforcement UG-36(c)(3).
I would base it off the larger diameter one because I know that a smaller diameter pipe is stronger
RE: reducer nozzle
RE: reducer nozzle
RE: reducer nozzle
