draftin design standard switch
I changed the design standard and gave it name, in customer default. When I open old model, still old drawing-standard is active.
How I can switch the standard?
RE: draftin design standard switch
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
www.nxjournaling.com
NX has been reset
While in drawing, Preference, drafting, drawing setting (use setting from standard)
But still is active the old standard
I did once change to the new standard but did not write down the procedure.
So how I can activate the new standard
Tools -> Drafting Standard...
Now this will only effect that next dimension/annotation created. If you're looking to update any existing drafting objects, they will have to be explicitly edited to that effect.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
