Results files deleted on re-open in Workbench 14.0
I'm having a strange problem in ANSYS workbench. On solving and saving results, if I close ANSYS Mechanical and re-open, the mesh and results are all forgotten. The analyses appear to be solved in Workbench (green ticks) but in Mechanical these can't be seen (lightning bolts). The results are present in the directory until Mechanical opens, then they are deleted, however they can be found in a backup folder which is automatically created.
This is only happening for one project, however I reconstruct it. The project has 4 models, I have tried separating these into smaller projects and re-solving but the problem reoccurs.
Has anyone had/solved a similar problem?
