Prepping kitchen carcase parts for cutting on a cnc tips please
Hi guys (SW 2006)
Can I pick your brains on setting up parts for a kitchen I'm designing (private job for family friend) to be cut out on a flatbed style cnc machine
I don't have any cam works or solid cam type software available.
1)what do I need to do to make my parts easy for the cnc operator to cut out?
Is it advisable for me to put the carcase parts into a drawing and save it out as a dxf at a scale of 1 to 1?
anything else
The cuts mostly consist of 5mm holes either right thru the board or 10mm into the board
the cut out shape and some slots 8mm wide by 8mm deep .
Can I add a sweep cut around the outside of the carcase parts and use that as a cnc router guide?
Thanks for your help
anything else
RE: Prepping kitchen carcase parts for cutting on a cnc tips please
Some of them are going to need work on both sides of the board( not a lot though)
Save each part separately, let the person doing the CNC work manage them efficiently to reduce material waste.
Chris, CSWA
SolidWorks '15
SolidWorks Legion
