saddle design
saddle design
saddle design
what are the last resort when we are designing horizontal vessel containing saddle structure
Trial 5: Move saddles to A = 0.2L and saddle angle= 120 and design ring stiffeners in the plane of the saddles
if vessel is not stable inspite of using 3 stiffners right over the saddle
next step is to increase the shell thickness
if my shell material is exotic material, client will not allow me to increase the thickness also
can you guys please give me any guidance to how make vessel structurally stable
RE: saddle design
Maybe give a sketch? I don't understand what your issue is. If complete ring stiffeners don't fix the local support problem then it sounds like it may not be a local problem. How is your vessel failing?
RE: saddle design
Assuming you're working your way through the Zick analysis- there are a number of different variables, different options, and different stresses. In order to use the design method effectively, you have to understand which variables affect which stresses. If you can locate the original paper by Zick, or the discussions of the method in the vessel design handbooks, that will help.
In general, where the problem is overstress in the shell itself, you'd widen the saddles, increase the saddle angle, add wear plates, etc., depending on which stress was exceeded.
RE: saddle design
Hi
Might help if you gave us a picture or drawing of the set up you're having a problem with.
Re read your post and then think if all you knew about the problem is what you have written in that first post how would you answer it.
