Sinumerik 840d UDE
Sinumerik 840d UDE
RE: Sinumerik 840d UDE
The easiest way is to edit your configuration file (probably mach\resource\configuration\cam_general.dat) to point to the ude file that combines the default with the Sinumerik.
Change this line:
USER_DEFINED_EVENTS,${UGII_CAM_USER_DEF_EVENT_DIR}ude.cdl,${UGII_CAM_USER_DEF_EVENT_DIR}ude.tcl
To this:
USER_DEFINED_EVENTS,${UGII_CAM_USER_DEF_EVENT_DIR}Siemens_Cycles_plus_ude.cdl,${UGII_CAM_USER_DEF_EVENT_DIR}ude.tcl
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Thank you Mark. The reason I want to use Sinumerik 840D is to change CYCLE832 (_camtolerance , 0,1 ), but after I set tolerances in Sinumerik 840 UDE it stays the same.
