help to calculate gear movement angle
hi..
need help to define the output angle by below two gear...
1) Drive Gear , module :0.7, gear teeth : 30, pcd: 21
2) Follower gear ,module : 0.7, gear teeth :25,pcd :17.5
if, drive gear turn angle 10deg, follower gear turn 8.3deg?(base on gear ratio :0.83?)
anyone can help teach me?
thanks...
thanks...
RE: help to calculate gear movement angle
Thanks for your help and reply.
really appreciated.
I think we should read as ;
Gear Ratio = N2/N1 = A1/A2
Therefore = 25/30 = 10/A2
A2 = 12deg.
N = Gear Teeth
A = Angle.
Hope my calculation is correct...
Thanks!
