conduction from under water
Looking to do a heat loss through the steel hull of a dry dock. Half is under seawater. The water temp is 50 degF and the OA is 25 degF and indoor conditions being 60degF. SO I did a typical UAdT equation for both above water and underwater sections. U of steel being 1.2 and dT for above water being 35=(60-25) and dT for below water being 10=(60-50).
I was told my heat required in the hull is over sized from what they have in an older dry dock of comparable size. I was told I should be taking more of a credit for the portion above water, because of the portion below water.
So I went back to basics and opened my thermo book to Fourier's Law, but the k value has to do with the steel hull, not the fluid difference?
I am still looking but could use some assurance if its good enough or assistance if I am calculating incorrectly.
knowledge is power
RE: conduction from under water
I didn't understand exactly what did you mean by (but the k value has to do with the steel hull, not the fluid difference?)
Say, for example, there were no steel plate. Would the heat transfer between water and air become infinite? Of course not.
I was treating it as steady stae since the dry dock is not moving, but since the waves are, you are saying I should take into effect convection?
knowledge is power
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
I will continue this in the thermo forum, if anybody is interested.
http://www.eng-tips.com/viewthread.cfm?qid=388527
knowledge is power
