Ductless Mini-Split with longest RS/RL run
Hi all, first post:
I run into this problem frequently, where I have an IDF or Electrical room in the middle of a large building or on a second floor and the RS/RL run ends up being 60'+.
Anyone have a go to mini split that has exceptionally long RS/RL run capabilities? I feel like if I developed a mini split system that could do 120' RS/RL runs I would make a fortune.
RE: Ductless Mini-Split with longest RS/RL run
knowledge is power
Size and run length limits usually varies by manufacturer. I don't typically size refrigeration lines for this very reason.
I've agree with EnergyProfessional, you should contact first the manufacturer & let them approved about upsizing the refrigeration lines.
