Importing Load combinations from ETABS 2013 to SAFE12
dears
i have more than 200 load combinations in Etabs model and i need to export these combinations from Etabs into safe , anybody can help me ................urgent please .
RE: Importing Load combinations from ETABS 2013 to SAFE12
Once you are clear about the general process, you may apply it to your model. You will then need to select all the load cases, you want to transfer to SAFE, using 'Select cases...' option (ETABS version 9), or some similar option in case available in ETABS 2013.
A good structural engineer is often a blessing for others.
