Casting Parts using part copy function
I am designing a number of cast parts using the part copy feature. I model the casting then part copy this part into a new file then cut away the machined surfaces that are required.
When i go to draft the component i specify the material as the casting part number.. Is there any way to do an auto call out to call up the document number of the part that has been part copied?
Andrew
Andrew
RE: Casting Parts using part copy function
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
That's an interesting problem. I can't find any way to link to the interpart linked file. I assume you are in ordered and the copied part is linked. The only workaround I can think of is to type it into an existing or new property and reference that in the callout. This would be a good post in the Siemens SE forum: http://community.plm.automation.siemens.com/t5/Sol...
I may ask it if you don't and you don't mind.
Bruce
One possible work around, temporarily add a view on the drawing of the cast part i.e. fed by the cast model.
This should allow you to use the property text technique I mention.
You should then be able to delete the drawing view and keep the property text linked to that model.
May have issues maintaining links if you move/rename files but might work.
Nice. That does seem to work for a callout. If you need it in a BOM I think it won't work.
The only other way I could think of is put in the view as KENAT mentioned, but don't delete it, put it on a hidden layer. This way it can stay in the drawing. This will be a good indicator if you go to do another drawing, you realize the number is wrong. Since its paramentric to the model, this would tell you that you need to insert a different model. Its also nice, because then the reference to the casting model shows up when looking at links.
I would recommend this if you are the only one working with the models. It could be confusing if someone else tried to work with your model. Its still the most parametric way to do it that I can think of. Just name your layer something descriptive like "HIDDEN CASTING MODEL VIEW".
As to it being confusing, if that's the accepted methodolody within a design group then no problem.
Sure you can post on the other forum, any help would be great.
Its strange that there isn't a simple way of doing this. There is functions and call outs for almost everything else. Its there a different way do design casting components with making the casting part and machined parts linked?
I don't want to keep manually putting the information in as sometimes the revision changes of the casting and it would be really nice to be able to update the draft with the casting revision updating also.
Andrew
Son of a Gun!
And it's intelligently linked so it will automatically update and be obvious to other users how it's structured. Actually it probably is the best way to do it.
Since it's a machining you just need to remove material and all the machining features like cuts and holes are available. IOW things that remove material. You could even add studs, thread inserts, etc. as items in the assembly if needed.
