Create a pipe using a spline as a guide - NX9
How could I create a pipe (OD 12mm and ID 10mm)using the points in the file attached?
MZ7DYJ
RE: Create a pipe using a spline as a guide - NX9
www.nxjournaling.com
MZ7DYJ
Tomas
MZ7DYJ
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
The main point of the topic is that I need to get the ability to modify very fast the location of the points, based on engineering request.
Will you, please, update your answer based on this new task?
Thanks!
MZ7DYJ
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
MZ7DYJ
Tim Flater
NX Designer
