View Information to String
HI,
I need a journal to get a drafting view information(Ctrl +I) text to string (VB) to perform a check...How to get that... I am using NX 7.5..
RE: View Information to String
You could use the Information.DisplayObjectDetails() method, send the output to a file, and then parse the file. But most (if not all) of that information can be obtained directly through the drafting view object's properties and methods.
An example of using .DisplayObjectDetails() can be found in thread:
thread561-386198: Deleting unused Planes
See the post dated: 11 May 15 20:08
www.nxjournaling.com
Thanks Cowski,
My Intention is to check that whether the view have Solid section curve or not (Drafting curve Type). If they Don't have I need to change the view label as VIEW "X" else it should be SECTION "X", I have found a method to get to the Viewlabelparms for editing the label prefix but unable to segregate the views, that they are projected from outside (using section method) or they are truly sectioned. The only difference I found is the true section views have the "solid section Line" other one is not (If I am not wrong).
Below is one method to tell if anything in the "section" view is actually sectioned or not.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
        Const undoMarkName As String = "NXJ journal"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        For Each tempView As Drawings.DraftingView In workPart.DraftingViews
            If TypeOf (tempView) Is Drawings.SectionView Then
                If IsSectioned(tempView) Then
                    lw.WriteLine(tempView.Name & " is sectioned")
                Else
                    lw.WriteLine(tempView.Name & " is NOT sectioned")
                End If
            End If
        Next
        lw.Close()
    End Sub
    Function IsSectioned(ByVal sectionView As Drawings.SectionView) As Boolean
        Dim sxSolidTags() As Tag
        Dim numSxSolids As Integer
        theUfSession.Draw.AskSxsolidsOfSxview(sectionView.Tag, Nothing, numSxSolids, sxSolidTags)
        'lw.WriteLine("num section solids: " & numSxSolids.ToString)
        Return numSxSolids > 0
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thanks Cowski...
I got this approach earlier but I have used some wrong references (I guess), It didn't worked for me..... Thanks for giving the correct code... I will update once it is verfied...2thumbsup
Hi Cowski,
I am unable to tag the view label for the temp view which u have highlighted a small help will be helpful...
Dim Tag1 As NXOpen.Tag = ' Need to tag the tempview label
Dim Labelparms1 As UFDraw.ViewLabelParms = Nothing
ufs.Draw.AskViewLabelParms(Tag1, Labelparms1)
Labelparms1.view_label_prefix = "SECTION"
Else
Labelparms1.view_label_prefix = "VIEW"
End If
ufs.Draw.SetViewLabelParms(Tag1, Labelparms1)
End If
Next
CODE
Dim viewLabelTag As Tag
ufs.Draw.AskViewLabel(tempView.Tag, viewLabelTag)
Dim validViewParms As Integer = -1
validViewParms = ufs.Draw.AskViewLabelParms(viewLabelTag, Labelparms1)
Thanks Cowski... It worked like a charm...bigsmile
Dim Tag1 As NXOpen.Tag = viewLabelTag ' Need to tag the tempview label
Else
Labelparms1.scale_label = False
End If
End If
Next
