RAR files unpack
RAR files unpack
I have downloaded a RAR file. When using WINRAR it now created a directory with little volume rars. filename.r00, filename.r01, filename.r02, etc.
Can someone assist me in explaining how to complete this unpack. When I unpack the first one, it creates a folder with a bin and cue file. When i start with the second on (filename.r01) it wants to overwrite the file exisiting.
Help?
Help?
RE: RAR files unpack
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
> Open the WinRAR application. Click on "File" and then "Open Archive" and browse to the damaged .RAR file.
> Press "Alt" + "R" on your keyboard. This will bring up the WinRAR repair dialog screen.
> Designate an easy-to-find location in the "Folder to put the repaired archive" box.
> Check the box that says, "Treat the corrupt archive as RAR."
> Press the "OK" button. Once it has finished repairing, a new archive will be built and placed in the location you designated.
> If instruction for WinRAR can't assist you make use of RAR Repair Toolbox https://www.repairtoolbox.com/rarrepair.html
