NX STEP214 Import into (Daimler) start model
Hallo everybody,
I am trying to convert a large (CATIA) assembly to NX via STEP214 interface.
My problem is that I need a specific start model in NX, a Daimler conform model.
Is it possible to configure the NX STEP214 converter properly to use a specific start model?
E.g. using the definition file „step214ug.def“ for that purpose?
As a workaround I tried to replace the “step214ugnullnx90_mm.prt” in the subdirectory where
the converter code is stored („STEP214UG“ directory). The result was that the converter also
used this part for the assembly models and the result was nonsense.
Perfect would be a possibility to define model- and assembly-start-part separately for the converter.
Thank you very much.
RE: NX STEP214 Import into (Daimler) start model
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I think for single part conversion your suggestion should work.
My problem is that I need to convert a large assembly (in batch mode) with lots of parts and sub-assemblies using the STEP converter batch
and therefore need a way to define my required start part for the converter-generated parts.
unfortunately no new postings here....
In my case the main problem is that the STEP converter uses the standard model “step214ugnullnx90_mm.prt” (from the STEP214UG directory)
for creating part-prts AND assembly-prts......(which is surprising for a CATIA user that an assembly can derive for a part
Replacing the “step214ugnullnx90_mm.prt” model with a Daimler-start-model leads to good conversion-results for the parts-prts BUT to faulty assembly-prts
I would be very grateful for any hint.
here is a link to one of them http://www.transcendata.com/solutions/proficiency/...
Currently my workaround is:
(1) do a STEP-Import batch conversion using a Daimler-model-part (substituting "step214ugnullnx90_mm.prt")
(2) do a STEP-Import batch conversion using a Daimler-assembly-part (substituting "step214ugnullnx90_mm.prt")
(3) merging both results, using the resulting model-parts of (1) and using the resulting assembly-parts of (2)
cheers
An assembly is a file which contains components, if these components are removed it's no longer an assembly , the file itself has nothing to do with this.
Therefore NX only uses one "stepxxxnullxxx.prt . You are, as you have noticed, free to replace this file with a tailored one, such as the Daimler template.
What's the difference between the Daimler part template and the assembly template ?
- You say in your first post that "the result was nonsense" - What was nonsense ?
Tomas
Part file have features groups and special attribute
Assembly Part have no feature group and another specual attribute
Didier Psaltopoulos
http://www.psi-cad.com
