Delete all existing Categiries
Hi John Baker,
In '09 there is a post about Deleting ALL Categories in one operation.
I've tried everything without success.
What haven't I tried?
Cheers
Ian
Automotive
EDAG Engineering Germany
NX9.0 TcAE 10
RE: Delete all existing Categiries
Are we talking about layer categories?
If so, select them all and press the Delete key.
www.nxjournaling.com
Yes Layer Categories.
NX9
I've tried that in 'Layer Settings' ... I can select all Layers, hit delete and nothing happens.
In 'Layer Category' I can only select 1 Category at a time. I've tried Ctrl + Select and Shift + Select.
Automotive
NX9.0 TcAE 10
Make sure the "Category Display" option is turned on so you can select the categories themselves (selecting the layers won't delete the category it belongs to). Once in category display mode, the normal Ctrl or Shift select methods should work as expected.
It's a bit of a bummer but the CNTRL and SHIFT methods don't seem to work in this case, unless I am missing something
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
NX 9.0.3.4 here, the normal selection methods work as expected in the layer category view. I don't know of any setting in NX that would change this behavior.
That got it.
So...
Layer Settings>
Category Display option selected.
DO NOT select the 'ALL' category
Multiple Categories can then be selected and deleted
Thanks once again
Automotive
NX9.0 TcAE 10
No, you cannot delete the "ALL" category; it has special standing. It is like the "entire part" reference set, it always exists in the part.
