help with pump selection
I'm going to use a hydraulic motor to move a conveyor. I've selected one based on torque and speed that it's needed. The specs are as follows:
speed: 279 RPM
flow l/min 265
torque: 3440
pressure: 260 psi
What I need to know is how do I know what wha kind of pump to use, and how to select the correct one to pair with the motor.
I'd appreciate any help . Thanks a lot.
speed: 279 RPM
flow l/min 265
torque: 3440
pressure: 260 psi
RE: help with pump selection
(you can't escape me)
Eaton 10,000 series disc valve motor. I selected it because it works at low speed with very hight torque. But dont know much abot the pressure and flow issue. Im starting from scratch so I thought I should select the motor and then go backwards to the pump and so on...
For more info. can contact via by e-mail.
