Sundyne LMC 337 High Frequency Vibration Problem
Hi everybody.
last week our subcontractor report a vibration test on our Sundyne LMC337 compressor.
They told us that there is a high frequency vibration pick value which shows that we have problem with thrust washers and we need to replace them.
I have a question that basically how is possible to understand Thrust washer problem using vibration analysis?
data are as followed:
LMC 337
input shaft: ~3000 rpm ~50 Hz Input Gear has 120 teeth
Idler Shaft: 6720 rpm 112 Hz Upper Gear has 53 teeth & Lower Gear Has 125 Teeth
High Speed Shaft: 15232 rpm 254 Hz High Speed Gear has 55 teeth
the pick amplitude is measured 3-4 mm/s on 3150 Hz on Axial Direction
LMC 337
RE: Sundyne LMC 337 High Frequency Vibration Problem
Cheers
Greg Locock
