Checklist of features
Hi!
I would like to know if there's any way of checking if all the features or parts are created.
I'm doing a project for a company that concerns the standardization of machine's interfaces. I have defined all the holes that should exist in every machine and saved every group of holes that define an interface as a part, so that I can go to the feature library and use them in any part.
After placing all the features in a part, I would like to check if every necessary feature is realy placed or if any of them is forgotten. I am using Solid Edge V20.
I would appreciate any help!
RE: Checklist of features
You could insert a small cylindrical part through the holes in the assembly environment and run an interference check. If you find an interference, most likely a hole doesn't exist at that location in the part.
--Scott
www.wertel.pro
