NX drafting creating dimensions in cm
Is it possible in NX 9 to change units in drafting to be displayed in cm instead of mm? Right now when I create new rapid dimension it is by default displayed in mm I want to change it be displayed in cm. In sheet settings only inches and millimeters are available. I'm wondering if changing of units display is possible.
RE: NX drafting creating dimensions in cm
but I found this doing an Internet search and I think it should point you in the right direction
http://swooshtech.blogspot.com/2014/07/how-to-chan...
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
In NX7.5 to change the units of the dimension RMC on it go to STYLE-> UNITS (last tab) -> go to the units and find cm in the pull-down . . . I hope NX9 is similar
For future dimensions you should be able to set what you want in PREFERENCES
I am not on my computer so I am doing this somewhat blind, so I hope I gave you the correct direction
Jerry J.
