I am trying to open one of my autocad 2008 files
I get the following message and instantly booted out; "fatal error unhandled c000000dh exception at 7303fac3h" any suggestions on how to fix the problem? All other files are fine.
RE: I am trying to open one of my autocad 2008 files
• Use the Recover command
• Open the file and press ESC key just before Regeneration/Error message, save to DXF, load, save as DWG, Audit
• Insert the complaining DWG as a block into an empty drawing
• Open/save the DWG in an older version of AutoCAD or AutoCAD LT or Actrix
Take a look on following useful resources and knowledge bases:
https://www.repairtoolbox.com/autocadrepair.html DWG Repair Toolbox
http://www.filerepairforum.com/forum/cad-tools/cad...
http://www.conceptart.org/go/questions/art/q/how-t...
Rhino is very tolerant and will often open (import) the file, but then you have import/export issues.
/RT
