U-Boot system
U-Boot system
U-Boot system
Hello everyone,
Could you please tell me what value I should consider as the Response Modification Coefficient (R) -as described in ASCE 7- for a system consisting of U-boot slab (crate type concrete voided slab)as the flooring system, shear walls and columns (that are not necessarily in the same axes)?
Many thanks
RE: U-Boot system
The seismic force resisting system is determined by the vertical elements. The floor/slab type does not determine the selection.
RE: U-Boot system
That's right. Are the columns creating a simple frame? If so, we should consider the connection type of "pinned" at the connection point of slab and columns (and shear walls), right?
