Start Directory setting
Dear Catia V5 users,
Just a helpful tip for you.
If any user wants to start the catia v5 session in a perticular directory (Normally project directory) then you have to change a setting so that you will start the catia session in same directory.
Go to tools >> options >> general >> documents >> DLname
click on Dlname >> configure >> add
then a path will be added just click on the path and say browse and then set which ever path you like
and then close the session and restart catia
regards
Amit Kulkarni
regards
Amit Kulkarni
RE: Start Directory setting
You can also configure tools >> options >> general >> documents : Other folder option ( use browse to select the one you want)
The best is still to configure an Environment with all those nice settings as an admin...
And put the UserSettings into different location for each environment... Like this you can really have different CATIA environment... You can even add Standards for Drafting, for 3D ( having solide in another color that the default one, surfaces and point using standard of your own)
If anyone is working on that and is using the CATStdLayersAndFilters.xml file, I need some feedback plz.
Have fun,
Eric
catiav5@softhome.net
