Boost to 600V from 480V
I am planning a project to replace some of our transformers that have been in service for many many years and are starting to show their age with the insulation on the windings going south. We are doing a boost from 480 3-ph to 600 3-ph using a couple of Square D dry type(50S3H) single phase isolation transformers. These transformers are configured using a HV of 480V and a LV of 120V to give us our boost. I am going to go back with the same type and model of transformer. Just wondering if anyone knew of a place with diagrams or info pertaining to the wiring of the windings. I can make a diagram when we do the exchange I suppose, but was wanting more information. Our plant is utilizing a 3 wire open Delta wiring system.
One other thing, these are 50KVA transformers and they do generate bunches of heat. The enclosures are ventilated with a fan on each one. Any suggestions on a better ventilation of the enclosures. The fans are very small and don't seem to make a real difference either way. Just looking for ideas. I am only running a load of around 420A but have the capacity for 600A. I don't plan on adding more load, but if I wanted to, then the heat would definately be a problem.
RE: Boost to 600V from 480V
http://www.federalpacific.com/literature/drytrans/FPTS-RTB-0701.pdf has information on buck/boost appilcations.
